Home > General > Pancaked Battery
Pufftmw
Pancaked Battery
Went to Ireland for a week, leaving the RRS guarding the fort. Came back and the battery was flat flat flat - not a glimmer not a joule of juice. I know what it was, I mislaid my sunglasses before I left and I checked the RRS just in case. Sometimes, when I open the car the SatNav display comes on and doesn't go off when I exit/lock the car, without turning the ignition on/off. This time I'd forgotten as under a bit of pressure, so obviously it flattened the battery over the time I was away.
I gained access through the passenger side and connected up my Ctek and it immediately started clunking sounds - it was the alarm going off - or attempting to. Left it an hour and no change, so jump started the car & left it for a while. What are we, 5 hours later and the charge indicator has just gone to 3 dots...
I really hope the battery is not foofed as its only a couple of years old and had been perfect up until now. Leaving it charging overnight and see what happens.
Post #614526 Tue Jun 08 2021 7:52pm
Brit Plumber
If it’s a Silver Calcium it will be toast, anything below 80% charge will kill one. I’ve had a duff brand new battery because it had been sat on the shelf for god knows how long. If it’s got silver in it’s title somewhere it will be Silver Cslcium. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #614533 Tue Jun 08 2021 11:12pm
Pressing radio on then off should also make it shut down[
Post #614549 Wed Jun 09 2021 10:06am
Pufftmw
If its a standard radio?
Took 18 hours to fully charge!
Post #614578 Wed Jun 09 2021 3:27pm
yes, pressing the knob twice
Post #614580 Wed Jun 09 2021 3:42pm
Pufftmw
Oh well - not for me but hopefully useful info for another member Thumbs Up
Its a
EA1000 Exide Premium Car Battery 017TE
Hopefully will be OK
Post #614594 Wed Jun 09 2021 7:29pm
Brit Plumber
It’s a Calcium battery.
If you start having issues, soft starting, dies after a few days of standing etc. Then I’d not even think about it and just buy a new one. Since I’ve fitted an AGM to mine, I’ve not had an issue since. That’s 3 new calcium batteries in 2019/20 and the AGM has been on since early 2020, so far zero issues and what’s better, the stereo doesn’t give me that ……will turn off in 3 minutes message until it’s been on for 25 minutes with ignition off.
Post #614597 Wed Jun 09 2021 8:00pm
Pufftmw
Started no problem after leaving it until Saturday to use again, so hopefully ok.
That'll probably jinx it Rolling with laughter
Post #614723 Sun Jun 13 2021 6:50pm
Pufftmw
OMG Andy! Bow down
My [complicated] other half [/complicated] tried to FaceTime me today and I couldn't hear her. She muttered something about being connected to her Landrover. Once I got her to actually listen to what I was saying, I worked out that she was connected to her RRS, so I told her to disconnect the BT connection. I then asked if she'd opened her car recently and she had, so I said go out and check to see if the SatNav was on, so we FT'd out there and it was, so then told her to press the Volume button twice and it went off!
Obviously I'm now an IT guru but its all thanks to you Thumbs Up
Post #614763 Mon Jun 14 2021 7:33pm
Laughing
Post #614764 Mon Jun 14 2021 7:53pm
