![]() | Home > General (L494) > Brake discs |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Tarbh Member Since: 12 Jul 2019 Location: Glasgow Posts: 8 ![]() ![]() |
I had to replace the rear discs after less than 10k miles!.
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Something wrong there, no way is that correct. Has the car been sat for a long time without any use? Why were the rear replaced? Which dealer was that? Joined the X5 45e club
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
I would be very wary of the dealer telling you that the brakes need doing. It's a classic and very common item that they flag up. Why? Because they charge a fortune for it, that's why. My advice first off would be to go somewhere else - not a LR dealer but an indie - and ask them to have a look at the brakes for you. In fact, I'd whip the front wheels off myself and have a look at the discs and pads and see what they look like. "Some corrosion" is a phrase used to make you feel concerned. It sounds scary without them having to actually explain exactly what is corroded, how much, and whether it's a safety critical issue or just a throw away line. As to "let's change the discs and pads and see if it gets better", well yeah great if someone else is picking up the tab. Do the brakes vibrate when braking lightly or when braking heavily? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Hi,
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
Get a second opinion from an Indy. My car went in for a service & they said the discs needed replaced due to corrosion. Car had done 6000miles. Got them checked, nothing wrong with them. Main dealer see them as a cash cow. Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e |
I use Paul at elite Land Rover in Clydebank |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
When I bought my current SVR, I took it in after about a week for SIM card reader not working. I got the health check video saying also my discs where showing corrosion and advise replacement at £4k. I called the dealer and thanked then.and stated if they where corroded then its their issue as car was supplied to me last week. Funny enough, after closer inspection they where OK! 2018 SVR |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
I don't know what brakes you have but my SDV8 had the big brembos. Terrible vibes due to the OME disc material. I did change pads and rotors and the vibes returned. Changed to Red Stuff brake pads and 100,000 k's still good and no black dust. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 147 ![]() ![]() |
Stroll on. Bloody unbelievable. |
