![]() | Home > Technical > Suspension Fault C1A20 still!! |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
I would have thought if the compressor is running for 5 minutes,, thats too long and would have suspected a leak or worn compressor but you say you had an AMK unit fitted a year ago. Was it a genuine AMK unit and not a cheap copy?. I would check for leaks,, do you know if the valve blocks were serviced when the compressor was changed? . I rebuilt my compressor some months ago and did the valve blocks as well and found a small amount of residue from the old dessicant in the seals. 2010 RRS, TDV8
Jontee Member Since: 05 Feb 2021 Location: Crieff, Scotland. Posts: 10 ![]() ![]() |
Thanks for reply Gogsy, Compressor genuine AMK, vehicle running for about 5 minutes before light comes on, not the compressor running for 5 mins. If the compressor was goosed surely it would not drive at correct levels all of the time?
Going back to the begining again, fault code C1A20 is pressure not rising quickly enough or pressure does not decrease when venting gallery. This all points to leaks or blockages in filters etc. What happens if you select access height then go to offload height?. I'm sure the pressure switch on these systems is part of the compressor so would only be as old as the compressor. Main valve block is behind the compressor, always worth a check for leaks and not contaminated with old dessicant.
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 ![]() ![]() ![]() |
Get the amk service kit from 4x4airseals.com and buy the valve block rebuild kit at the same time, all in... 65 quid for both items. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Leaking air tank, from the sounds of things
As usual spot on Mikey, I had, I thought checked everywhere for leaks, but yesterday my Grandson drove
