Home > General > RRS 2010 facelift rear spoiler
Bazzer58
2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
Hi.
I have just bought a 2010 RRS SE.
The rear spoiler has suffered the de-lamination problem and so has to have a new rear spoiler.
Q. While I have the spoiler off, can I fit a reversing camera as they have in the HSE? Is the wiring already there and will the display recognise a camera is then fitted???
Any help would be great fully received.
Thanks
Post #614154 Tue Jun 01 2021 10:06am
Update you profile!
It's worth fitting one while you are there, but it will need enabling with a GAP IID or similar
Post #614156 Tue Jun 01 2021 10:43am
Bazzer58
Thanks.
Do you know if the wiring and connections are already there?
PS. Profile updated.
Post #614157 Tue Jun 01 2021 11:24am
I don't.
If it's anything like the D4, the wiring is the other side of the tail gate and you need a short adaptor loom
Post #614159 Tue Jun 01 2021 11:29am
You need to look under the head lining at by the top of the tailgate, if you look at the the two connectors marked if there are wires in pin no's 1 & 15 (co-ax type cable I think as goes to the front touch screen, in plug C0144T and pin's no's 8 black wire (earth) & pin 9 green wire (live) in plug C2739T then you may already have the wiring if no wires in those positions then probably not, you will also need the link wire LR016142 unless you manage to buy a rear spoiler with the camera and lead still attached. The basic wiring circuit is quite simple and straight forward as no control module involved only front screen.
Post #614184 Tue Jun 01 2021 9:44pm
Bazzer58
Thanks very much for the info.
Investigation is obviously needed.
Post #614212 Wed Jun 02 2021 10:46am
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Camera upgrade aside, why do you need a replacement spoiler? My one started to delaminate (first noticed as it was causing a rattle when closing the boot lid) but it was a very simple job to remove it and re-bond the two halves together with appropriate adhesive. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #614263 Thu Jun 03 2021 3:29pm
Could be apart from the A/B variant there were two different spoilers fitted, one with camera aperture and one without, as the O/P has a SE it may not have the provision in the spoiler for a camera.
Post #614288 Thu Jun 03 2021 10:54pm
Bazzer58
Spolier
I have just purchased a replacement spoiler from China.
It has a hole for a reverse camera which my old spoiler had, it was just blanked off.
I have had the vehicle checked and the wiring is there ready for a camera.
Just been in touch with Land Rover and they looked up the vehicle and gave me a price for the camera and bracket. But they wouldn’t give me part numbers which I reall need to try and source it elsewhere as they haven’t got stock.
If anyone can help with these part numbers I would be very grateful.
Post #616681 Thu Aug 19 2021 1:17pm
Bazzer58
Top part of the spoiler has been re deployed to somewhere on a motorway.
Post #616682 Thu Aug 19 2021 1:19pm
Bracket LR023566
Camera LR031791
If you buy a s/h camera from the likes of fleabay make sure it is the one for standard single camera system and not one for the the surround system, easy enough to tell the difference standard one has 2pins the surround one's have 4pins the other thing is you need to ensure you are buying a good camera as some of the early one's could develop a fault and reverse the image the fault being the camera not the car. Unfortunately I don't think you can tell until fitting the camera.
Post #616698 Fri Aug 20 2021 9:03am
