![]() | Home > General (L494) > Disclock size |
Kot Member Since: 07 Jan 2021 Location: UK Posts: 92 ![]() |
Eagle77 Member Since: 21 Feb 2021 Location: Buckinghamshire Posts: 69 ![]() ![]() |
Thanks - I considered stoplock but its quite easy to cut a steering wheel to get it off whilst disclock covers the whole thing making it more hassle and noisy hence hopefully a better deterrent. MY2022 HSE Silver D300 in Firenze Red with black contrast roof
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 260 ![]() ![]() |
The small will fit but it is a just fit, so I have the next size up. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Small will be tight.
Yup...medium..
As an aside, I found the disclock caused pressure indentations on the leather, so I have a towel (which has approx 3 inches turned over and sewn to create a pocket over the top of the wheel) which I put on between the lock and the leather. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
In a test, Auto Express found that the Stoplock Pro was as hard to break as the Disklok (more on that below), and reported that cracking it open isn’t exactly a quiet affair, either.
Mike London Member Since: 22 Jul 2014 Location: Cotswolds Posts: 58 ![]() |
I went with the small size (there is some adjustment, with the largest setting there is enough looseness ) and bought one of these to protect the steering wheel .... https://www.disklokuk.co.uk/shop/steering-...r-disklok/ 2014 RRS AB Santorini Black |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Are you sure you need one of these monstrosities? I mean play it out: you hope it’s a deterrent, but determined thieves know how to remove them in seconds. You won’t get an insurance discount. In the unlikely event it gets nicked, you claim. Every time you drive it you have to manhandle this metal party killer. The one time you do not reapply it would be the one time it gets nicked. (Sod’s law theory).
I can see where you are coming from - the area I live in, apart from catalytic converter theft, car related theft is almost solely cars being stolen from driveways at night using keyless entry so I would only really use the disc lock when parked up overnight. Seems to be thieves try their luck on across several villages looking for an easy target. None of the cars stolen appear to have had any sort of mechanical device nor used faraday bags to stop keyless entry so I am thinking a combination of visual deterrent plus other security features should work. Alternatively I am thinking of getting a couple of retractable bollards fitted to my driveway. MY2022 HSE Silver D300 in Firenze Red with black contrast roof
Agree a vidual deterrent coupled with other measures..I have a ghost immobiliser and have disabled keyless entry.
lardie Member Since: 22 May 2013 Location: Essex Posts: 4 ![]() ![]() ![]() |
Eagle77
