Home > Technical > Exhaust Gas Temp Sensor and DPF Help
Benrrs2021
H i All,
So i have just cleared the red DPF full warning to allow further investigation as i am confident the DPF is not blocked but it has triggered due to too many failed regen requests.
on a run i notice exhaust temp bank 1 sensor 1 is way off the mark! all other read around 400 with the pre-dpf sometimes climbing to 650 to clear soot but bank 1 sensor 1 stays at around 130. if i put my foot down and really boot it i can get the sensor to keep up with the others but as soon as i let off it drops off again.
can anyone tell me where this sensor is located i am guessing it is duff and needs changing out and the car wont allow a dpf regen with the parameter missing?
see below log from IID, you can clearly see the sensor in question as the red line and you can see where i put my foot down and it catches up.
Post #613445 Sat May 08 2021 7:57pm
DrRob
If it’s the same as a 4.4 tdv8 in the L322 then one of the sensor will only shoot up when second turbo is opened up with a throttle above 2500rpm * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #613450 Sun May 09 2021 9:48am
Benrrs2021
Yes i did a little research last night and found a thread on the jag 3.0 tdv6 (same motor) that showed exactly the same temp readings. I think it is after the secondary turbo. Thanks for the help!
Post #613452 Sun May 09 2021 11:24am
