Home > Maintenance & Modifications > P132b-22 (6c) Fault Code
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
So upon inserting fully charged battery into car, the usual ‘It’s cold’ warning lights came on. My beast doesn't respond well to temperatures below 3 degrees. Big Cry
1.Special Programmes not available
2. EPB not functioning correctly
And a new one
3. Engine Fault.
As usual I ignored them as the car fired up straight away, even at -1, and off I went. Pulled out into the A road and accelerated,,,,,,, and not a lot happened. I got to 60 eventually. No smoke - no bangs. So whilst looking at the rear propshaft bearing that was knackered my ‘tame’ mechanic (my son) had a look at the Turbo actuators on both turbos. Expecting the fault to be the front passenger one; ie B, we started there. Turns out it moved freely, but the drivers side one was seized? A liberal dose of silicon freed it and now working as they should.
Any ideas why actuator B was found by the IID, when it was actuator A at fault? Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #612250 Sun Apr 04 2021 11:03am
That code does relate to the R/H turbocharger control "A" which I thought would be the drivers side, strange why the IID would say "B" though.
Post #612254 Sun Apr 04 2021 12:42pm
MartinsTDV8
And that will teach me to follow a video on uYube Bow down Previously owned 1999 Disco 2 TD5
Post #612265 Sun Apr 04 2021 6:24pm
