Home > Technical > Electrical buzzing noise rear |
dazza2802 Member Since: 05 Mar 2021 Location: Liverpool Posts: 26 |
Hi all. Got a 2011 RRS HSE, and I have not had it long at all and recently when “playing” with the access height and off road height of suspension, I heard an electrical working noise as it was raised and lowered, which obviously I expected, but then when the suspension finished doing its stuff, the same working type noise was still there around the rear suspension.. that can’t be normal ???? Or is it ??? |
Sun Mar 21 2021 11:02am |
Great, thanks for that. The noise was louder around the area you mentioned, so I guess I must have a leak as it was still running after it reached all the different heights... thanks again |
Sun Mar 21 2021 11:49am |
just an update, the compressor just stays active for about 30 seconds now after it’s finished raising and lowering. I presume that’s about getting the system to an optimum level |
Sun Mar 21 2021 3:20pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Although I've not actually timed it, that sounds about right |
Sun Mar 21 2021 5:27pm |
