![]() | Home > General > Tailgate doesnt Lock |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5122 ![]() ![]() ![]() |
Mine does this occasionally.
evets Member Since: 11 Jun 2020 Location: Manchester / Bolton Posts: 59 ![]() ![]() ![]() |
Buttons do nothing fob does nothing glass top closes but lock does not engage? |
Faulty latch on the lower half I guess.
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
If I've got it right, the bottom tailgate will not open when the top half is open. There's a trick you can do by using the shaft of a screwdriver to trip the top tailgate's latch (which is on the top ot the bottom tailgate) as per the PowerfulUK video. Then you can open the bottom tailgate as well, which you will need to do in order to remove the trim without breaking things.
