Home > Technical > Limp Mode Again.
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Limp Mode Again.
Hi Lads
Over the last few weeks the Sport 2006 2.7tdv6 has started going into Limp Mode again. It clears when switched of and re-started again. Managed to read a couple of Fault Codes of it today.
1 P0234 Turbo Overboost Condition.
2 P132B Turbo Boost Control A Performance.
The car had a new Turbo a few years back when this happened before, as far as I know the Turbo that was fitted had the updated Actuator which hopefully wouldn't stick.
Just wanted to go over again the checks I should start and see if anyone has any ideas of anything I have missed.
1 Check how free Actuator is/Lubricate.
2 Check Turbo Hoses.
3 Check MAF Sensor.
4 Run Additive / Cleaner through System ( any suggestions as to what one to use).
Cheers Jock Big Cry
Post #611407 Fri Mar 12 2021 10:58pm
4. Wynn’s vvt cleaner (purple bottle)
Post #611419 Sat Mar 13 2021 10:38am
Jock 77
Thanks Andy
I will pick up a bottle of that and try it. Thumbs Up
Post #611456 Sun Mar 14 2021 10:58am
