![]() | Home > Maintenance & Modifications > Handbrake module? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
I think it’s the shoes they say require servicing
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi just following on from Andy and his wise words I was advised by a RR Independent who looks after my RRS he said same around EHB saying you should use it the same way as you would with an manual car and old handbrake.Use it put car into Park and use the EHB.He says the majority of problems are down to simply the EHB not being used regular and it starts to seize up and then when you do go to use it the stress created causes problems and faults. |
