![]() | Home > General (L494) > Dashcam again. Power supply issue |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 ![]() |
On further testing and tinkering, it seems to be dashcam related and not the supply coming from the fuse box. Now I need to figure out why my new dashcam is more fussy firing up than my old one. |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
Can't speak for the Garmin but on the Thinkware dash cam there is a voltage setting designed so that you don't drain the battery. If there is the same on the Garmin then maybe that's affecting when it powers up. Having just said this your issues seem to be exactly the opposite of what this setting would seem to do, but maybe there a setting on the Garmin somewhere that's affecting it - or its also faulty. Robin
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5124 ![]() ![]() ![]() |
Could it be anything to do with it the ecu's "going to sleep" so as to speak when car turned off for longer periods, not sure what year your car is but is Fuse 52 not possibly the aux power socket for the cubby box? and thought they stayed live after ignition turned off and powered down after a set time with ignition off, don't know for sure only a suggestion though.
Issue is a strange one. I don’t use my car much and even less at the moment. I’ve had the car hooked up to my ctek and the dashcam comes on as expected and desired. I’m wondering if when the battery gets low, certain circuits don’t come on until the battery has a bit more juice, or perhaps it’s the camera that’s very sensitive to voltage supplied to it. My old one used to come on all the time, this Garmin seems more sensitive. |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1293 ![]() ![]() |
Same issue as OP since new on a L494 with a fuse tap.
I have a power magic pro that I haven’t installed yet, partly because it’s so bulky vs the other simpler DC converters I have and secondly as I don’t use the dashcam in parking mode. It was going to be my last resort in case I couldn’t get anything else to work.
My post on installing the Thinkware may help you regarding wiring: http://www.rrsport.co.uk/forum/topic45687-15.html
Thanks, how did you feed the cable through into the tailgate? I can’t quite tell from your pic.
The new position for my Thinkware rear is here
