Home > General > RRS l320 ACE pipes repair.
Jontee
Scotland
Hi, can anyone tell me what size OD are the metal ace pipes on RRS l320 &
what size couplers need to join pipes.
Thanks.
Post #609578 Fri Feb 05 2021 1:13pm
the_wombat
There are a couple of threads on here which contain the info.
Search ACE pipes leaking or look for the author Brit_plumber.
I think the OD is 10mm as I bought some for mine but never used them as i replaced the complete pipes in the end.
Post #609598 Sat Feb 06 2021 8:58am
Jontee
Scotland
Hi Wombat,
Thank you for your prompt reply, I thought also that the pipes are 10mm.
I have seen several posts regarding cutting & joining using 10mm copper pipe & plumbers
brass compression couplers, however I believe the pressure in pipes @ circa 135 bar would
would be way to high for both of these items? I thought that I would contact my local Pirtek
branch & see if they could make up Hydraulic hoses to replace damaged parts, but wanted
to know for sure that they were 10mm OD before doing so.
Thanks again, Be Lucky.
Post #609599 Sat Feb 06 2021 9:38am
mgrover
i used a 10mm pipe coupling to the rubber hose piping since there was no way it would open. been fine for a few thousand miles since.
my issue was more ensuring the filter drain plug doesn't snag the oring since that leaked like a bitch. same with the ram connectors.
Post #609984 Sun Feb 14 2021 6:29pm
Disco_Mikey
The pipes were never designed to be cut. To do so is just a bodge, IMO
Do the job right, or give it to someone who will...
Post #609988 Sun Feb 14 2021 8:23pm
mgrover
then order the pipe that goes to the pump i think? before you start Laughing
its fairly cheap either way, i wanna say 90ish quid?
Post #609989 Sun Feb 14 2021 8:24pm
Jontee
Scotland
I realize that the pipes were not designed to be cut, however they were poorly
designed in the first place! i.e. the way they were routed, the poor retaining clamps which just hold all
the mud salt etc. & then rust through.
I actually think that cutting pipes where they are good & using High pressure hydraulic pipe & unions will
be better, last longer, than original design.
Post #610001 Mon Feb 15 2021 3:21pm
