![]() | Home > Technical > No Auxiliary battery in RRS 2015? |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 ![]() ![]() |
I’ve just changed my big battery and I was fully expecting to change the Aux also. However when I looked I realised my car has a big battery and a capacitor rather than the AUX battery. My car was registered December 2015 but a 2016 model which is when they first started using the capacitor. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
I could well be wrong but I think you may find with the earlier RRS2 only the 4.4 TDV8 and cars built for cold climate market's had the Aux battery fitted.
bmszabo Member Since: 10 Aug 2019 Location: Tilburg Posts: 65 ![]() ![]() ![]() |
So, chapter 2.
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Sounds reasonable. My RRS is a 2006 model, so a bit different, but I know that manufacturers have introduced monitors in the ECU for the battery condition, which could be why your dealer is saying that it needs a "reset". The ECU need to know that the battery has changed.
Laurie100uk Member Since: 01 Nov 2020 Location: Bristol Posts: 41 ![]() ![]() |
Stick it on a ctek conditioner mate, my car had no start/stop and an airbag warning light. I was going to replace the battery but got the ctek mxs 5.0 instead and it fixed both the issues |
