![]() | Home > Maintenance & Modifications > Is there a how to, to change a rear parking sensor - RRS1 |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5124 ![]() ![]() ![]() |
Did u remove the bumper ?
Ha no I didn’t or thought you had to...... 2006 2.7 TDV6 HSE in Cairns Blue. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9139 ![]() ![]() ![]() |
Bumper cover off - about 6 screws from memory, and then the sensor can be popped out. Worth checking the wiring loom whilst the cover if off to make sure no damage to the wiring. That can cause issues that mimic sensor failure. The loom is a separate item from a plug in the NSR wing across the bumper. 2012 SDV6 - it's missing a couple of cylinders
Remove left light too (to unplug bumper wiring)
Thanks everyone. 2006 2.7 TDV6 HSE in Cairns Blue. |
