![]() | Home > Maintenance & Modifications > Non starter☹️ |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5125 ![]() ![]() ![]() |
No glowplugs fault codes on the 2.7
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 321 ![]() ![]() ![]() |
Yes I’ve read all that Andy, as the weather got colder she was on occasion sluggish and lumpy from cold so I had done some research on the plugs, easy job “if” they come out nightmare if they don’t 😳 Steve
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9141 ![]() ![]() ![]() |
12.8V isn't a low battery. That's a fully charged battery. Glow plugs are in need of replacement. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
HDC fail is a sign of low battery |
Take it to a couple of garages as if you’re going to trade it and give it the Basil Fawlty finger “or else” |
It may be but 12.8V is fully charged, especially if it's after a failed try to start. A duff cell could show 12.8V until it was placed under load and then it would drop out and show 10-11V. So that suggests the battery is ok and fully charged. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Well I’ve given the battery a bit of a charge this afternoon and the air temperature was 1.5 when I came to work and she’s fired up okay, fingers crossed she’ll start in morning 🤞
Batteries only a year old, I’ll do a cranking voltage test tomorrow when I get up. I replaced it when we got her because I was getting lots of lights after starting, when I checked the cranking voltage it was 9volts new battery was as you say 10/11volts. Steve 2005 2.7 TDV6 HSE, ongoing project. 1998 Volvo V70 R auto FWD, Back on the road again. 1999 BMW Z3 (owned from new) garage queen. |
