![]() | Home > General > Heated windscreen not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
yes it could |
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
How can I test the relay? Is there another one I can swap it with to test? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5137 ![]() ![]() ![]() |
It's R9 70amp grey one, same one (R7) used on air suspension could try swapping with that one. R6 is also the same but I think that is something to do with engine management, personally I would leave that one alone.
Swapped the relay with the Ride Height Control and same issue. Ride height still works fine but windscreen heating still not working. I doubled checked the fuses and both are okay, but there is still no voltage passing through them.
So to be clear.
