Home > General > L320 Side step trim
Lhard92
L320 Side step trim
Hi all. Excuse the mess been a hectic few days. Just went out to my car and discovered this.... no idea why it’s happened but does this appear to be an easy fix and what do I need to do/ look out for in the morning? My car is a 11 RRS autobiography. Sorry i know this is basic rubbish for you guys I’m just a new owner trying my best to not mess anything up lol.
 Thanks
Liam
Post #608657 Fri Jan 15 2021 8:59pm
geoffsnook
You could pop rivet back on or pop a screw in it Thumbs Up
Post #608658 Fri Jan 15 2021 9:13pm
nobby
Hi, one of mine did exactly the same. After a clean and ensursing all the holes where free of the old rivets I used raised pop rivets - Th whole job took 30 mins and the hardest part was getting my belly between the vehicle to look for the holes Rolling with laughter
Post #608686 Sat Jan 16 2021 12:39pm
Father Jack
Same thing happened on my 2012. As others say a rivet or bolt will fix.
Post #608691 Sat Jan 16 2021 1:14pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Re: L320 Side step trim
Just buy new ones. There not that expensive RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #608696 Sat Jan 16 2021 3:14pm
mgrover
I used some rivets to make it happen. Drilled old out and put new ones in. I do remember the rivets needed to be a bit longer than what I had, cant remember exactly size, maybe 10mm?
Post #608697 Sat Jan 16 2021 3:50pm
Ash3
Remember same thing happened on my old D3 driver side one a few years back.
Used a rivet gun to rivet it back on....after good clean...worked a charm and only a few pence as I had the rivet gun and rivets.
Post #608710 Sat Jan 16 2021 6:20pm
Lhard92
Just picked up a rivet gun from Aldi 😂😂😂 will let you know how it goes. Thanks
Liam
Post #608748 Sun Jan 17 2021 3:55pm
Vermont_Jack
I'm in the process of painting my side runner trims in colour matched Santorini black. I removed the steps entirely and removed the trim by breaking off the rivets (70% of them had already corroded away) - they’re prone to corrosion and frequently fall off.
I’m just waiting for the final coat of lacquer to harden, then I’ll attach the trim back to the steps with self-tapping screws and large washers. If you have a rivet tool, then that will work too.
I noticed the steps themselves were rusted to bits, so I rubbed them down and sealed with direct to rust. Not a long term fix but will help a bit. If your rivets are corroded, I’d guess that the steps themselves are likely quite rusted - could be worth whipping them off and taking a look. The steps are held in the mounting brackets by 6 x 10mm bolts on each side (3 brackets on each side with 2 bolts each). Very easy to remove with a 10mm spanner and socket. They can be removed without jack the car up.
Post #608865 Wed Jan 20 2021 2:46am
I previously re-riveted some with stainless steel pop rivets less likely to corrode, fortunately here they don't use salt on the roads though.
Post #608868 Wed Jan 20 2021 7:34am
Lhard92
Jack, I’d love to see the outcome of you spraying black when it’s finished. Can you share a picture? Thanks
Liam
Post #608886 Wed Jan 20 2021 7:36pm
Vermont_Jack
Of course - I’ll post photos in the next few days after they’re all put together again. I’ll post a few pics of the individual pieces and the self tappers also for anyone searching in the future.
Post #608889 Wed Jan 20 2021 8:15pm
nobby
Darn, why didnt i use stainless Bow down
Post #608898 Wed Jan 20 2021 10:37pm
To be fair it's a habit I've got into over the years, any nuts, bolts, screws etc. that are prone to corrosion on vehicles like heat shields, mud flap, bumper fixings etc. that can be replaced with stainless fixings just to try and make it a bit easier if it has to come apart again.
Post #608905 Wed Jan 20 2021 11:56pm
