Home > General > Front heated wind screen not clearing two strips L320 2012
drexal
United Kingdom 2012 Range Rover Sport Supercharged HSE Santorini Black
Hi all,
Merry Christmas,
I just wondered if anyone knows what could be causing this issue (Please see attached image)?
I read through the history of the vehicle and it looks like in an old service they said issue with screen not clearing and said they changed a fuse to fix this. But when looking through the manual i can't find a fuse labelled for heated windscreen.
There a quite a few chips and a little crack in the windscreen so i'm wondering if the heating wires in the screen have been damaged in those two areas
Any help advice would be hugely appreciated. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #607924 Mon Dec 28 2020 4:30pm
Oldandconfused
From what I've read on here, there are 2 circuits, one for each side with separate fuses. Looking at your photo's I would say you're right; damaged elements.
Post #607925 Mon Dec 28 2020 4:42pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
It’s a common problem and looking at your picture they are not in a good place on the screen. There are two fuses 40amps each, one for each side of the screen. If it was a fuse half the screen wouldn’t clear. Looking at your picture it’s broken elements.
Only solution is a new screen.
Time to “have an accident with a hammer” and get a new one.
Post #607926 Mon Dec 28 2020 5:00pm
drexal
Thanks Oldandconfused, i'll go back to the manual and look at the fuse info again and see if i can see where it labels the driver side windscreen. And if i'm able to find the fuse number and its ok, i guess that will confirm the screen chips have caused this.
Thanks again for the help 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #607927 Mon Dec 28 2020 5:01pm
drexal
Thanks LandPhil Thumbs Up 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #607928 Mon Dec 28 2020 5:04pm
The Two fuses are in the Engine Bay fuse box.
Post #607937 Mon Dec 28 2020 8:51pm
drexal
Thanks so much Col, super interesting, i will try and check on these fuses tomorrow and see if this fix was ever done, and or if one side has blown. Thanks so much again Thumbs Up 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #607940 Mon Dec 28 2020 9:07pm
Dealer tried to charge me £600.00 + for new screen way back but said they couldn't do it under warranty and tried to say a stone had chipped screen and damaged element, turned out to be £1.25 fuse which I discovered myself.
Post #607942 Mon Dec 28 2020 9:16pm
drexal
Wow they are unreal. Did your issue look like mine, with a strip or two not clearing or was yours the whole of one side of the screen not clearing? 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #607943 Mon Dec 28 2020 9:21pm
It was quite a few years ago as car was still under warranty, but to be fair if I remember correctly it was the whole L/H side not working, not just a couple of strips.
Probably not fuse in that case but they are located in Engine Bay Fuse Box, they are in a bank of six fuses located to the rear and slightly left, sort of pink square 30amp rated "J" type fuse, position 2 is right hand side and 6 is left hand side.
Just remembered my original post, would appear neither side worked.
https://www.rrsport.co.uk/forum/topic39380...windscreen
Post #607944 Mon Dec 28 2020 9:26pm
drexal
Sorry this conclusion is nearly 3 years old. I hate it when i read through threads and there no actual concrete conclusion at the end. So i thought its only fair to update it, we recently had a stone fly up and crack the windscreen right down the centre. Had a new windscreen installed and i can clarify in my case the two lines that wouldn't demist previously must of been caused by a small previous chip in the windscreen that damaged the heated wires in the screen. As now the whole screen completely clears since fitting the new screen. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #633650 Fri Jun 09 2023 11:01pm
