![]() | Home > Technical > 2.7 EGR replacement |
Blank it with a kit and map it out if you get an EML |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 316 ![]() ![]() ![]() |
Blank them off |
SomersetRRS Member Since: 18 Nov 2019 Location: Somerset Posts: 65 ![]() ![]() ![]() |
Thanks, Devon Z. Assume you didn't need to map it out as you're an early car? |
Thanks, DrRob. Can most Indy's map it out? |
Through my research you don’t need to remap the EU3 engines (2.7) EU4 (3.0) need a software patch.
Thanks, Devon Z. Food for thought and I better do some more research. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Later 2.7's need a patch after blanking as well, 2007 rings a bell but I may be wrong with the date.
I’ve registered on the DISCO3 forum as well lots of stuff on there for the 2.7. Oldandconfused is correct about post 2007 2.7’s Steve 2005 2.7 TDV6 HSE, ongoing project. 1998 Volvo V70 R auto FWD, mothballed future project. 1999 BMW Z3 (owned from new) garage queen. |
Hi all - being doing a bit more research on this. So my car is an 8A chassis so will definitely need a patch.
Blank it with an eBay kit and then if you get an EML then there is a local Somerset chap that can help. Need to find his name for you. Better still, buy an IID Bluetooth and then get the Bell Auto Services patch done over internet. Get the lot from Bell.
Woody32 over on Disco site is your man for the job
Thanks, DrRob. Seriously thinking about a IID. Would have helped me out on my air compressor issue, I think.
Try dropping him a PM Visitor from fullfatrr.com
Will give it a go... |
