Home > Faults & Fixes > rear parking sensor
StevieT
United Kingdom 2005 Range Rover Sport TDV6 S Izmir Blue
rear parking sensor
i wonder if anyone can help. My parking sensors don't seem to be working. I have a flashing light on the parking sensor switch on dash that goes off if pressed. I have runan OBD scan & it is showing u0159 no communication with parking assist module. Checked fuses all ok. ? any advice would be very much appreciated. ( 2007 RRS 2.7TDV6 HSE AUTO ).
Steve One Life - Live It !!
Post #607554 Wed Dec 16 2020 4:51pm
what fault code reader do you have ?
When you select reverse for the first time, do you get an error tone from the rear?
If no, its 95% likely the speaker has failed.
It's fitted in the rear boot behind the left trim.
Jaguar and fords use the same speaker.
If you have a meter, you can measure the resistance of the speaker. should be 50R I think.
If the system has been faulty for some time, there could be other faults present.
these :
https://www.ebay.co.uk/itm/PARKING-AID-SPE...Swfs9fFse9
Post #607559 Wed Dec 16 2020 6:02pm
StevieT
only generic elm bluetooth scanner using 'car scanner' app.
but same code given from RAC dude other day.
will check speaker in boot
thx. One Life - Live It !!
Post #607561 Wed Dec 16 2020 7:06pm
