Home > General > L320 door seals? |
Dunc101 Member Since: 16 Nov 2017 Location: Bedfordshire Posts: 30 |
I have a lot of road noise coming from my front passenger door, - itโs been getting worse over the past 6 month - so I was going to replace both primary and secondary seals to reduce the noise (suspected perished seal(s)). But before I do, are there any aftermarket primary / secondary door seals that block out more noise than the LR / Britpart seals?
Sat Nov 14 2020 12:08pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1231 |
I have noise from the front passenger seat (snoring). If I took a photo and got found out Iโd be dead 2006 2.7 TDV6 HSE in Cairns Blue. |
Mon Nov 16 2020 3:03pm |
Stevepd - ๐ Your seals must be really effective! ๐ |
Mon Nov 16 2020 9:18pm |
peterjj - will do. I canโt find any other options, so in lieu of any other suggestions here, Iโll go for the britpart seals I found on lrparts.net. ๐๐ป |
Mon Nov 16 2020 9:21pm |
Update - secondary seals changed. Thats the easy part. Primary seals (unbeknownst to me through lack of research) are stuck, rather well, to the door frame. One removed, and new seal applied. Seal does not stick. Britpart seal returned and refund given. LR seal has now been sent to me - awaiting my time to fit it.
Wed Dec 30 2020 1:08pm |
