Home > General > L494 2015 HSE Right headlight out, fuse ok, no errors i |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 575 |
Either the main headlight earth under the wing or the headlight control module
Thu Nov 12 2020 7:43pm |
toti62 Member Since: 14 Dec 2015 Location: Reykjavik Posts: 3 |
Do you have the partnumber for this headlight module, and how much do you want for it? |
Fri Nov 13 2020 8:57am |
PM Sent |
Fri Nov 13 2020 11:36am |
Well I have found out the problem, the thing is that each headlight has a ground cable attached to the body, Inner fender to be exact. That connection is located under the wheel well shield on each side. so you would need to remove the wheel and remove the plastic wheel well shield to access the cable. This cable had corrasions so when pulled it broke completely. I got this fixed for both sides. So now you know what to look for when your headlights die on you. Thanks for the help. |
Fri Nov 13 2020 6:04pm |
Thats what I said on my first post
Fri Nov 13 2020 9:49pm |
