![]() | Home > General > RRS , TURBO REPLACEMENT COSTS |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
If you end up needing new turbos, reconditioned ones are likely to be a false economy. Budget for new units and then add a grand for the fitting.
eddyeggs Member Since: 03 Nov 2020 Location: luton Posts: 13 ![]() ![]() |
hi, so the price was given to me yesterday and he mentioned reconditioned turbos, i myself would not have reconditioned turbos fitted, ,
The TDV8 does benefit from correct oil changes and from being allowed to spool down for a minute or so after being run. This helps to prevent the oil from burning/congealing in the feed/drain pipes and around the seal.
wow, that is really good news , 100k , i myself would ensure i followed any steps to ensure the turbo's were kept to a good standard,
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
My turbos lasted until 110K this year. I got my TDV8 10 years ago with 30K miles and oil changes have always been done in lne with recommended timescales
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
2 new turbos plus fitting on my sdv6 £3700 or so at an indy. Recon ones are risky.... 10 hours labour or so, body off job. |
