Home > General > Boot lid opened on it's own
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hi folks
This morning I got up to find my boot lid sitting full open, both keys were unusually at the other end of the house and out of kids way so I can only assume it opened by itself. I do remember reading on here of a similar fault in the past but all I can find in searches is for the previous 2 piece door so can anyone advise whether this is a known fault for the facelift door and what to check?
As it's only happened once then I'm hoping it's a spurious opening, but being an RRS it's probably wise to get clued up the potential fixes Laughing . 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #606081 Fri Oct 30 2020 11:16am
Buckster
This has happened to me recently on a couple of occasions after heavy rain. Makes you question if you actually closed it in the first place but on both occasions I definitely have! 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #606118 Sat Oct 31 2020 9:11am
Brit Plumber
Did it not set the Alarm off? Dare I say that is a little alarming. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #606119 Sat Oct 31 2020 9:52am
insiorc
It was definately closed as it hadn't been driven in over a week and I'd been pottering about outside near it till early evening so would have seen if it was open, and I've no idea if it should have set the alarm off as it wasn't locked (and not likely someone passing would open it due to where I live). I can't put it down to rain either as it was a rare dry calm night, must've been the calm before the storm as tonight or 99% of other nights and I'd likely have a boot soaked in water and hinges well tested fighting against the wind.
Once the weather improves and probably now in a few weeks as I'm about to start my work rota then I could pull out the switch to see it any moisture could have shorted the connections, it's about all I can think of other than an ecu gremlin. 13MY Range Rover Sport Autobiography SDV6 - mine
Post #606127 Sat Oct 31 2020 3:13pm
Brit Plumber
Yeah the Alarm wouldn’t go off if it wasn’t locked. What year is it? My car locks itself if the keys not in the vicinity. 2019 5.0 SC SVA (Current)
Post #606130 Sat Oct 31 2020 3:50pm
insiorc
It's a late 2012, I've never known it to lock itself but I suppose it's possible it can 'see' the remote wherever it is in my house depending how far apart they can talk. I believe the remote can transmit quite far when pressing a button, but I'd expect the keyless side of things to be a much shorter range, probably very close the RRS or otherwise it wouldn't be very secure. It will re-lock if unlocked by the remote but doors not opened within a given time. 13MY Range Rover Sport Autobiography SDV6 - mine
Post #606152 Sun Nov 01 2020 11:00pm
Funnily enough I checked my fob/remote a while back out of curiosity, I think it was when I was playing about with disabling the keyless entry, in the end couldn't be bothered doing it and having to dig the fob out of my pocket all the time to lock/unlock the car. It had to be within about a meter if using the door handle button to lock/unlock, but using the Fob buttons it would lock/unlock from 25/30 meters away. If you unlock but don't open a door after 60 seconds it relocks itself.
Post #606153 Sun Nov 01 2020 11:13pm
insiorc
Col, 1 metre, that makes sense from a security point of view.
This morning my FBH wasn't running even though I went out to the RRS a bit earlier, so I checked my BM2 battery monitoring app to see if it was due to low voltage even though I charged it yesterday, I saw the FBH had run an hour earlier than planned but that was an easy fix - I'd never driven since the clocks went back so I just set the correct time.
But while in the app I noticed some spurious happenings in the days leading to the boot self opening. Normally when parked the green line is steady just dropping slightly over the days, but on the 28th about 9am the readings get a bit funny. This continues over the 29th then into the 30th when about 8am there is a considerable dip which I'm wondering if it has anything to do with the boot opening. I only noticed it open about 10am when I closed it, the battery readings then level off again into the 31st.
Tonight on my way home from work I connected the battery app again to see how it was going when I noticed battery low warnings and no alternator charging as the voltage was down to about 12.2V. It's looking like there could be an issue so I disconnected the battery and shorted the tails, on reconnection I got a larger pop than I expected but everything appears to be working, I just set the clock. So I'll see how it goes tomorrow morning whether I can get to work or not, but hopefully it'll have reset and run happily......
Edit: corrected BM2 monitor, I'd wrote AM2 13MY Range Rover Sport Autobiography SDV6 - mine
Post #606183 Mon Nov 02 2020 10:38pm
Strange coincident, fitted a BM2 monitor yesterday out of curiosity to see what they did. Laughing
Post #606184 Mon Nov 02 2020 10:49pm
insiorc
It's a handy tool, this example shows it can give information that would be very difficult to obtain without it or similar. 13MY Range Rover Sport Autobiography SDV6 - mine
Post #606185 Mon Nov 02 2020 10:55pm
knwatkins
They are cool little devices. I forgot to disconnect mine when I sold my L320 Big Cry I'll have to order another one... Kev
Post #606186 Mon Nov 02 2020 11:19pm
insiorc
Well good news, I think. I left the Ctek on all night then everything appeared to be charging fine today both going to then home from work. I didn't enjoy how chilly it was as I didn't brave running the timed FBH but all was good with lights on, seat and steering wheel heaters on so it coped with a decent electrical load. What I'm not sure if normal is the BM2 was showing a running voltage of around 14.92V which I thought a bit high, but is this normal for the RRS with AGM battery not long off charge, I thought about 14.7 was normal? 13MY Range Rover Sport Autobiography SDV6 - mine
Post #606221 Tue Nov 03 2020 10:27pm
As only recently fitted the one on mine haven't really had much time to play with it, but look like with everything switch on air con, headlights, seats etc. obviously no FBH being petrol, shows charging at 14.65v at 2500rpm, with everything switched off shows 14.8v it does also have AGM battery. They were the highest figures it went up to don't know if any of that info is any use at all.
Post #606224 Tue Nov 03 2020 10:57pm
insiorc
Yes that's helpful, thanks. It's probably to be expected then as a battery not so freshly off charge may hold the volts down a point or two of a volt. I'll keep an eye on it over the coming days.
One thing I thought ironic was just today the Android BM2 app got an update, and the bug fix was for charging reporting issues. I'd have been wondering if that was all the problem was other than I had confirmed yesterday's voltages with my Fluke meter. I was impressed how accurate/similar the readings were. 13MY Range Rover Sport Autobiography SDV6 - mine
Post #606225 Tue Nov 03 2020 11:12pm
LG8340
England 2013 Range Rover Sport SDV6 HSE Lux Santorini Black
That's interesting because overnight 31st Oct / 1st Nov my boot-lid self opened. RRS (MY13) Santorini Black SDV6 HSE luxuary
Gone: Evoque, Freelander 2, Mercedes 320 CLK, Porsche 911's
Post #606250 Wed Nov 04 2020 5:36pm
