Home > Maintenance & Modifications > Which Suspension Airbags
derekmines
So it seems I need a couple of new rear suspension airbags, no great problem other than the variety of different ones available...
How do I tell if my '10 Facelift 3.0 TDV6 L320 has active damping or not....
I know I have ACE, so I think that if i don't have active damping then the part I need is LR06419A but if I have AD then the parts are LR032651 & LR032652
Am I correct and how do I tell !
Post #605985 Tue Oct 27 2020 1:12pm
Stevepd
Hi Derek,
From the AF parts exploded diagram, can you see the umbilical chord at the top of the strut or not?. It might be of help or I might be a hindrance Whistle
https://www.advancedfactors.co.uk/steering--suspension-22-c.asp 2006 2.7 TDV6 HSE in Cairns Blue.
Post #605988 Tue Oct 27 2020 4:22pm
If you can see this wire in the illustration coming out from the top of the damper you have Variable Damping, have a quick look under your n/s/f wheel arch as that is the easiest one to see, or it is on my s/c which had it as standard, I think it may also have been standard fitting on all later variants except the SE.
Post #605989 Tue Oct 27 2020 4:39pm
The twisty road icon to the left of the "normal" setting on Terrain Response is the easiest clue. 2012 SDV6 - it's missing a couple of cylinders
Post #605996 Tue Oct 27 2020 8:36pm
derekmines
That's interesting then as I only have 5 settings on that dial... a google search seems to indicate the twisty road icon would be the 6th.
I guess that means I only need normal airbags then!
Post #606311 Fri Nov 06 2020 9:47am
A quick check of one of the rear units (easier to get to the top of them than the fronts) to see if you have a cable and an air hose or just an air hose, would also be worth doing just to be sure. If it's just an air hose, then they're passive units. 2012 SDV6 - it's missing a couple of cylinders
Post #606315 Fri Nov 06 2020 10:09am
N/S/F is the easiest to see if you have a wire coming out of the centre of the strut as you can see directly on to the top of it, without raising suspension or at least you can on mine.
Post #606316 Fri Nov 06 2020 10:17am
Just been and looked at mine and the view is pretty much the same front and rear- so we're agreed that he has no excuses for not being able to figure it out on way or another. Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #606318 Fri Nov 06 2020 10:45am
derekmines
Alright, alright, I get the picture...
Will stick my head in the wheelarch shortly!
Post #606320 Fri Nov 06 2020 12:27pm
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Now remember about safety when putting any part of your body under the vehicle Rolling Eyes
Post #606324 Fri Nov 06 2020 1:08pm
derekmines
Not sure there's much in there to get concerned about the loss of to be honest lol
Post #606333 Fri Nov 06 2020 4:58pm
knwatkins
If you don't have the active dampers, Derek, the part number you need is LR016419.
The part numbers you have for the actives ones are correct. Kev
Post #606339 Fri Nov 06 2020 8:35pm
