Home > Faults & Fixes > Headlamp washer issue, advice?
Preston-rr
United Kingdom 2010 Range Rover Sport SDV6 HSE Sumatra Black
Hi, the headlamp washer on my 2014 RRS is not fully retracting back into the bumper on the passenger side? Any advice?
Thanks 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #605273 Tue Oct 06 2020 8:28pm
Turdmon
Not sure if they are the same in RR’s butwhen I had BMW’s I had one that did exactly this. It turns out that behind the bumper there’s a little pump which is more like a cylinder with a piston inside ( think of a bike pump). When you apply water it pops up and sprays. These can get crap inside and that makes them stick. Apparently crap washer fluid doesn’t help, but I’m not sure whether to believe that. Anyhow, you can either pull the pump out and replace or you can overhaul some of them.
BTW - whereabouts in PR are you? Smile
Post #605392 Thu Oct 08 2020 8:22pm
Preston-rr
Ok thanks. I’ve got Mick Cookson (aka Flack) giving the car the Ince over tomorrow, plug the diagnostic in etc and he us also going to hopefully work his very extensive magic on the headlamp washer. I’m in Kirkham bud. Where are you? 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #605393 Thu Oct 08 2020 8:26pm
Turdmon
T’other side o’t watter mate. Longton. PR4 too though! Smile
Post #605394 Thu Oct 08 2020 8:39pm
Preston-rr
👍🏻 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #605396 Thu Oct 08 2020 9:02pm
