![]() | Home > General > Spare Key? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
you can take a photo of the key blade, and then use keys in the post off ebay, who will send you a metal cut blade.
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 344 ![]() ![]() ![]() |
Thanks Andy!! Andrew Kennedy |
https://www.disco3.co.uk/forum/key-fob-pro...90764.html
I used them for create a second key and programmed it myself with the IID tool. Key worked fine although it required a squirt of WD40 and its been fine since. 2006 2.7 TDV6 HSE in Cairns Blue. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5137 ![]() ![]() ![]() |
Would not advise WD40 in ignition barrel/key, use a Graphite Powder if it is sticky, as the WD40 will gum it up over time.
