Home > Technical > fuel trims with subfeedback
mgrover
right so these are my fuel trims from the SDD tool. Finally i can get a clear picture as to whats going on
Anyone know why its so high? It only seems to get better at the higher loads/rev ranges. feels like its some injector issue?
Post #604781 Tue Sep 22 2020 8:39pm
Vacuum leaks impact trims big time at idle.
Where at full throttle they make little difference.
I’d post here. See if you get any help.
https://schrodingersboxqm.com/forums/forum/the-garage/
Post #604783 Tue Sep 22 2020 8:58pm
mgrover
ive smoke tested the Censored out of this car with no luck. also this is the image with the legends. its lean above idle as well
thats a bit more descriptive
Post #604785 Tue Sep 22 2020 9:07pm
