Home > Technical > Ride heights
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Ride heights
Trying to check suspension in a newly aquired 2009 RRS.
In high I have three wheels at 20 in and one at 21 in when measuring from wheel centre to arch.
What is the standard figure and how long should it take to lift from normal to high.
thanks in advance.
Post #604773 Tue Sep 22 2020 6:12pm
Post #604777 Tue Sep 22 2020 7:23pm
With that name are you from YouTube fame ?
Should lift within 5 seconds. Instantly really if compressor good and filled the tank.
Post #604784 Tue Sep 22 2020 9:04pm
Pistnbroke
Thanks Col ..
Do you have a figure for the High Position? Any idea of the time to go from normal to high ?
Post #604792 Wed Sep 23 2020 6:57am
Mine takes around 10-12 seconds to lift from standard to off-road height, that's if I start it up and put it straight into off road after being left overnight. Can't really remember what the difference between normal and off road height is, but sure someone will come along who knows, I don't think you can calibrate the normal ride height and the off road height separately if that is what you are thinking, calibrating normal height automatically sets the off road height, but again not totally certain on that one either.
Post #604793 Wed Sep 23 2020 8:05am
Pistnbroke
That's helpful..spent 10years in Noosa ..wish I was there now.
Post #604794 Wed Sep 23 2020 8:19am
Col is correct, the off road and access height settings are just offsets from the calibrated normal height. You can't set them individually.
Summary:
Access mode is approx. 50mm lower than normal height.
Off road height is approx. 55mm higher than normal height.
High speed mode (activates if speed over 100mph for more than 5 seconds) is 20mm lower than normal mode.
Extended mode occurs when the vehicle senses it's grounded (driver can't select it) and is approx. 50mm higher than off road mode. Drops to off road height if the speed is more than 2mph for 45 seconds.
Additional extended mode can be selected by the driver if already in Extended mode. This is done by pressing the brake pedal and the suspension up button for 3 seconds. This gives whatever lift is left in the suspension system. 2012 SDV6 - it's missing a couple of cylinders
Post #604795 Wed Sep 23 2020 8:34am
Pistnbroke
In high three wheels are showing 20 in and one 21. I guess the height sensor on the 21 wheel needs adjusting or has been replaced in a sloppy manor.
Post #604796 Wed Sep 23 2020 8:42am
Seems like it. 20inches is high anyway so it'll benefit from being calibrated correctly.
Remember that you'll need a four wheel alignment doing too. The camber changes with wheel vertical movement and if it's being aligned with the wheels at their current height, it'll be out when you calibrate to the correct height. 2012 SDV6 - it's missing a couple of cylinders
Post #604797 Wed Sep 23 2020 8:52am
See, I knew somebody would know. Rolling with laughter What possessed you to move back to good old Blighty, nearest I ever got to Noosa was Brisbane and Sanctuary Cove on the Gold Coast. Cool
Post #604798 Wed Sep 23 2020 8:56am
Pistnbroke
Is the calibration done physically by moving the ride heigh sensors or part of an electronic diagnostic programme
Post #604799 Wed Sep 23 2020 9:02am
No, you do it using something like a Gap IID diag. or EAS tool or the likes of. Well worth investing in one.
https://www.gap-diagnostic.com/
Post #604801 Wed Sep 23 2020 9:11am
samd
Summary:
Should that not be 100 Kph? When I had a 12v feed wire break en route to Chesterfield from Cromer, every time I hit 60 mph, the system 'told me off' and to slow down
Post #604802 Wed Sep 23 2020 10:12am
Definitely 100mph reverts back to on road mode when speed drops back down below 80mph for 30 seconds.
Post #604805 Wed Sep 23 2020 10:42am
knwatkins
Different location, Andy. YouTube Piston Broke lives in South Wales. Kev
Post #604830 Wed Sep 23 2020 11:48pm
