![]() | Home > General (L494) > Electric handbrake - use or not? |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 263 ![]() ![]() |
Apologies if this appears a daft question but this is my first automatic after 40 odd years of manual cars. I have had a couple with electric handbrakes before but as the auto box has a 'park' setting, is the handbrake really necessary?
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1195 ![]() ![]() ![]() |
My driveway is a bit sloped, so i use it first, and then put it in P so as not to strain the gearbox --
Thanks, I suspected it was some device like this. Trouble is I am biased against the electric brake based on previous experiences of it locking up, once on a level car park. Two different cars, but both Volvos.
richamartin Member Since: 16 Dec 2012 Location: Cotswolds Posts: 251 ![]() ![]() |
Am i missing something.... Doesn't the electronic parking brake activate automatically anyway? |
Not on my model. Will release automatically, but can only be applied via the switch, according to the manual. RRS HSE Dynamic SDV6 2014
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 923 ![]() ![]() |
Mine's does not engage automatically. Just checked |
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 ![]() ![]() |
That's what I thought, I know mine does. Ferrari F430 Spider F1 MY17 RRS AB V6 2CV6 Special |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 952 ![]() ![]() ![]() |
I'm of the opinion that if you don't use it regularly you are asking for trouble,, dirt / brake dust are the big enemy off these systems and your going to get both of them whether you apply the brake or not. Do you think that after not using it for 12 months it's going to be perfect when the MOT tester try's it.. I use mine all the time, but I have the rear brakes cleaned and adjusted correctly at the annual service,,,, never been a problem since. 2010 RRS, TDV8
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
Absolutely, use it or lose it |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 252 ![]() ![]() |
My MY17 automatically engages the handbrake when in Park and I am sure my previous MY13 Evoque was also engaging the handbrake in Park MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
MBSVR Member Since: 27 Jun 2020 Location: Bedfordshire Posts: 26 ![]() ![]() |
my 2020 SVR automatically engages |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
You can change the settings in the CCF files to either have the park brake apply automatically or manually.
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
From (very expensive) personal experience I would say absolutely leave the thing well alone.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9060 ![]() ![]() ![]() |
So long as the EPB is checked, cleaned and adjusted correctly at each service (and more frequently if used off road), there shouldn't be a problem with it. What causes problems is poor servicing and lack of cleaning/adjusting the mechanism. 2012 SDV6 - it's missing a couple of cylinders
