Home > In Car Electronics > Front parking sensors
Guyzer73
So with the new stereo installed I thought the parking sensor graphic worked, however, I've noticed now that the 2 outer front sensored are handed/mirrored on the display, whilst the inner front sensors display as they should.
Before I go down the bumper off route can somebody confirm how the sensors are connected to the harness? By which I mean is each sensor plugged in separately to a specific location on a connector or not?
The reason I ask is because the sensors where reinstalled when I had the AB kit installed and whilst the audio obviously works regardless as it distinguishes between front and back, not left and right the graphic does and as explained above it shows the outer sensors handed.
I've found this but it doesn't show if the are individual connectors on the sensor side or not, nor does it show where it's located.
Therefore, could anybody tell me where to find the parking aid harness connector (C2277) and if indeed the individual sensors are connected individually or not. If not I can only assume they installed the sensors incorrectly and will need to redo those with the bumper off.
Alternatively any other advise?
Thanks
Post #603776 Wed Aug 26 2020 10:20am
You can't usually plug the sensors in wrong.
You would be best to remove the RH headlight, and locate the connector under it.
Ideally un pin the 2 brightly coloured wires and swap them round.
Note, when one fails it will report the wrong one as failed. And that's really gonna annoy someone in the future! They are annoying as it is
Post #603778 Wed Aug 26 2020 10:47am
Any Use?
Post #603779 Wed Aug 26 2020 11:22am
Guyzer73
Thanks Col, Andy K will give that a shot Thumbs Up
Post #603815 Thu Aug 27 2020 9:20am
gogsy1956
Having just had my bumper off to change the
AC condenser I found all the wiring connections under the drivers side headlight unit
 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #603839 Thu Aug 27 2020 5:46pm
Guyzer73
Thanks Gogsy Thumbs Up 2006 RRS S/C CONSTANTLY under modification...
Post #603917 Sun Aug 30 2020 7:04am
