![]() | Home > Technical > Drivers seat back wiring |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
Hi
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
I think you may be able to remove just the complete seat backrest in situ. if you need to, but bear in mind there is a airbag in the seat so might be worth disconnecting the battery and leave for around 20 min's first to discharge any residual power as a safety precaution, if you have a short somewhere if it is at all possible wouldn't want to accidentally fire the airbag.
Thanks all. Useful diagrams col. -----------------------------------------------
There’s some sharp edged steel bracing in the back rest so be careful not to cut yourself. My drivers seat headrest TV kept tripping the RSE because a wire had got sliced open by a sharp edge. 2019 5.0 SC SVA (Current)
Thanks to all for the advice and support.
