![]() | Home > General > SVR side steps |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 262 ![]() ![]() |
Hard points should be the same. I believe SVR requires a different set due to lower trim being different? Also, 2020 MY incorporated pre wiring to make deploy-able side steps easier. Not sure if SVR's can have deploy-able side steps? 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
markymarkf Member Since: 08 May 2017 Location: Essex Posts: 143 ![]() ![]() |
Thanks for the info
The fixed side steps should be possible, they work on all the SVR's so far. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
thanks for that
