Home > General > Replace one turbo or both?
RobP
My drivers side turbo went pop on Saturday @ 107K miles. Oh well I got away with it for 10 years of ownership Big Cry
Trying to get quotes for repair at the moment and just had the first garage say will only replace the turbos as a pair and only use genuine new borg warner
Anyone got any advice do I need to do both? Are the refurbished turbos worth looking at? I know its a big job and needs body off to do. What price would be reasonable?
Cheers all TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #603064 Mon Aug 10 2020 8:39am
Eaters
My main interest in your post is that I guess that, more sooner than later, I'll have to have this job done, I can't speak with any knowledge to answer your question, but my gut feeling is that if you're going to have the body off, you should attempt to do everything you can afford to do. Certainly I'd do both turbos - if ones gone the other cant be far behind. There's probably other stuff that could be looked at???
I believe it is supposed to be around a day job to remove and replace the body, so labour costs would be anything between about £500 and £1500 just for that bit. You don't want to have to do that again in a hurry. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #603069 Mon Aug 10 2020 9:58am
Boxers
Haven't had to replace mine yet but have spoken about it with my indie & definitely replace both at the same time he estimated that around the 100,000 miles mark is the average if looked after some may last longer & some may go sooner I'm presently on 93,000 miles and have £3,000 tucked away when required.
2007 RRS TDV8
Post #603077 Mon Aug 10 2020 12:10pm
At that age, I'd just replace both and be done with it. Be very annoying to get one done and then have the other one fail a few thousand miles later. 2012 SDV6 - it's missing a couple of cylinders
Post #603085 Mon Aug 10 2020 1:11pm
RobP
Thanks all, car has just left me on the back of a transporter to the garage.
Going with both turbos replaced for new units and hope that I can get another 100k out of them. He is going to do the front active anti roll bar bushes for me while body is off as just a 15min job and the current ones are squeaking
Still cheaper than buying a replacement car and have done so much to this over the years of ownership it feels the right thing to do TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #603088 Mon Aug 10 2020 1:42pm
mgrover
am a bit curious, why do turbos cost so much? is it because its a body off job and that takes a while? i mean after the bodies off i assume you just bolt off the old turbos and bolt on new ones? am completely oblivious to how the jobs done so feel free to treat me like a moron Razz
Post #603093 Mon Aug 10 2020 2:22pm
Eaters
Good question. I am sure the experts will come back with an answer, but I guess and element of it will be just that its a Range Rover! Robin
Gone:
MGZTT 190 2.5
Post #603094 Mon Aug 10 2020 2:25pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Would be worth checking the condition of the Active roll bar pipework too when the body is off. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #603097 Mon Aug 10 2020 3:06pm
The turbos are around a grand each so that £2k before you've started. Then it's a couple of hours plus each way to take the body off and replace it. That's a few hundred more depending on garage and hourly rates, obviously. Then chuck in the VAT and any bits that need to be renewed in the strip down and rebuild and you're up to £3k and more quite easily. 2012 SDV6 - it's missing a couple of cylinders
Post #603100 Mon Aug 10 2020 3:54pm
mgrover
For a grand each I think I'd use the opportunity to upgrade :p
Post #603106 Mon Aug 10 2020 6:22pm
Upgrade? 2012 SDV6 - it's missing a couple of cylinders
Post #603110 Mon Aug 10 2020 9:04pm
mgrover
Yeah I'd assume some better turbo to stick on :p
Post #603140 Tue Aug 11 2020 2:14pm
RobP
Car back from AJ Land Rover and all good Thumbs Up Lets hope the new turbos last as long as first pair
Post #603586 Fri Aug 21 2020 9:09pm
