Home > Maintenance & Modifications > L320 Coolant Tank change...Faulty sensor/float
djb222
Replacing the Coolant/expansion tank on a Range Rover Sport L320 or indeed the L322 and the Discovery 3 due to a faulty sensor is a very common issue. The usual cause is not the sensor, but the float becoming porous and not reading the water level accurately, in other words sinking.
So, to solve the issue and stop the fault code constantly showing on the dash it needs replacing.
This video shows you how to replace the tank, it's the same unit on each car mentioned and although access will vary between the cars the approach to carrying out the job is very similar, so watch my warts and all attempt at the task. It's straight forward but fiddly.......
Post #602702 Mon Aug 03 2020 8:30pm
DrRob
Thumbs Up Just done the one on my L322 - it's a different shape though. * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #602711 Tue Aug 04 2020 7:59am
Shaun W
Need to do mine, but struggling to find a replacement tanks, could anyone tell me the part number please? 2010 HSE TdV8 in Stornoway Grey.
Powerful Roof Rails and Spare Wheel protector
Post #626324 Sun Aug 28 2022 8:28pm
Alexdc12
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Java Black
I used this
https://www.ebay.co.uk/itm/163238856842
Post #627346 Thu Oct 13 2022 8:41am
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Did mine recently for the same reason old fluid bottle never lost a drop but fed up with the warning message, new ebay bottle fitted now I seem to lose coolant
Rolling Eyes
Post #627353 Thu Oct 13 2022 5:47pm
Alexdc12
So do I, I think.
I was defo loosing coolant as got the error, I looked and the bleed valve on the edge coolant pipe was leaking, I tried to turn it and it snapped!
Managed to replace that but I think I am still loosing a small amount somewhere, that it I have airlocks clearing
Post #627357 Thu Oct 13 2022 7:24pm
Phil2k
I need to do mine, it never really bothered me apart from the light cause I knew it didn't loose any fluid, until I had the inlet manifold replaced. Checked the water the other day and the tank was almost bone dry. Bought a dye kit from ebay and found this. Does anyone know if its a gasket or O ring before I undo the pipe
Post #627505 Thu Oct 20 2022 8:21am
Alexdc12
I too have been loosing coolant since having manifold replaced, found that the top coolant hose was leaking water, just removed , dried and cleaned and refitted and think it may finally be ok.
Post #627510 Thu Oct 20 2022 9:37am
NoExpert
That looks higher up judging by the pipe having dye on it. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #627520 Thu Oct 20 2022 3:43pm
Phil2k
It wasn't dye on the fuel rail, just a scratch on the sticker that showed up under the uv light
Post #627592 Sun Oct 23 2022 5:30pm
brimfull45
Did you mange to sort out your leak? I have a leak in the same place?
Post #627805 Mon Oct 31 2022 5:50pm
brimfull45
Hi,
Did you mange to fix the leak? I have a coolant leak in the same area.
Post #627806 Mon Oct 31 2022 5:57pm
