Home > Maintenance & Modifications > Wanted; plastic sill covers
Oldandconfused
I knew that the side steps were a bit, well, tired and a round to job was buying an after market set and fitting them to the current brackets. However, on looking under the car, the brackets actually look beyond salvaging. Having had a bit of a read up, I am a bit put off by the prospect of seized/sheared nuts (oo er missus) and the brackets needing a bit of percussion engineering to get them to fit.
I am now thinking that the easiest solution it to bin the steps and find a set of non-cut sill trims and stick them on.
So, if anyone has a set of uncut trims surplus to requirements, please let me know and we can discuss price etc. Thumbs Up
Post #602377 Tue Jul 28 2020 6:59pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
Might be worth posting this in the "For Sale & Wanted" section ... 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #602387 Tue Jul 28 2020 8:34pm
Oldandconfused
Ah yes, good point. No idea how to move it over, so will post it again. Cheers.
Post #602419 Wed Jul 29 2020 12:47pm
gogsy1956
Bite the bullet,,, the brackets will certainly not be worth saving. Shear the heads off the bolts,,you might be lucky and get a couple out, drill and re-tap the holes 8mm, just done mine,,,,,, not a big job at all. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #602440 Wed Jul 29 2020 6:56pm
Oldandconfused
Easy for you to say....... Sad Laughing
Post #602449 Wed Jul 29 2020 8:30pm
Eaters
If you decide to go down the removal route, I've got a pair of uncut sills from my 2008 TDV8. Not sure if they fit yours or not.
 Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #602473 Thu Jul 30 2020 8:44am
Oldandconfused
you have a PM Thumbs Up
Post #602476 Thu Jul 30 2020 9:27am
Same part number now 2005 through to 2013 so imagine the should fit without any problem.
Post #602528 Thu Jul 30 2020 10:08pm
Oldandconfused
Thanks Col Bow down
Post #602537 Fri Jul 31 2020 8:24am
