![]() | Home > Maintenance & Modifications > Falling out of love with my RRS |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
I had the same noise issues with my 2010 TDV8. As well as the loud creaking/squeaking at low speeds (which generally occurred once the car had been on a run or in warm weather), I would also sometimes get a clonk from the front on really rough roads.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I really appreciate your reply, I was getting quite despondent.
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
I've got mine booked in for replacement in a couple of weeks time, the estimate shows 1.6hrs of labour |
abiopete Member Since: 27 Feb 2020 Location: Manchester, UK Posts: 184 ![]() ![]() ![]() |
Same issue here, had the front ARB bushes done, improved significantly.
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
I have this same issue with mine. How do I know if my car has ACE/Dynamic anti roll bars? |
This may help?
25 quid per bush plus a couple of hours labour, think I'll give it a go. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9109 ![]() ![]() ![]() |
And people wonder why punctuation is so important... ![]() 2008 TDV8 - it was a labour of love and is much missed |
Is this the correct one? I have the yellow cap reservoir so I'm guessing I have stability control.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5116 ![]() ![]() ![]() |
At £3.70 a bush they must be top quality.
![]() ![]() ![]() MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
I'd pay the extra to not get sh*tpart, unless it's a tried and tested part that has been verified by other members. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
The link I posted has 3 different versions. I was planning on going for the genuine ones for £18 each and obviously not the £3 ones |
Hi' wasn't having a go at you in anyway, could have worded it a little better I guess, it's just that people do buy this cheap crap part's and when it doesn't last it's the vehicles that's a piece of s**t.
