![]() | Home > Technical > Parked on a slope - the back drops after a day or so? |
PeteF74 Member Since: 01 Jul 2020 Location: South Wales Posts: 83 ![]() ![]() ![]() |
I have a drive that slopes down and I park the RRS on the slope. I have noticed that after about a day if I don't use it, the back drops down randomly making a clicking noise. It doesn't go to the stops but it does drop from the height at which it was parked.
Hi Kev
How much gap should there be from the top of the tyre to the wheel arch when it is dropped? Mine definitely seems a bit lower on the nearside but as I say, I am not sure if the drive slopes a bit.. |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
No it is not normal - the vehicle should remain parallel to the surface not the horizontal. My drive is also on a slope and height does not change while parked.
Thanks Garry. This is what I mean. Some say its normal and some say its not. So I am not quite sure what to do about it.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1557 ![]() ![]() ![]() |
For what its worth, mine drops down a about an half an inch shortly after I've turned it off. It is noticeable if I'm leaning on it to get something out of the boot after switching off. And if left for any length of time that is say a day or two, it seems to be a bit lower all round as you can see it raising itself when the engine is switched on. Robin
Hi Robin
Yes - at no time is mine down to the bump stops Robin
I wouldn't worry about it Phil. Mine behaves exactly the same as Robins and yours. All of my struts and airbags are under 12 months old, valve blocks have all been cleaned and lubed up and my compressor is only 18 months old. I'm 100% confident that mine yours and Robin's are exhibiting normal behaviour.
