Home > General > Wheel Wobble/Vibrations
sportgoogle
Took the Sport to have its wheels balanced as the fronts wobble/vibrate at approx 60mph.
The garage took a look at the tyres and said there's no point because of the tyre wear on each tyre is causing the problem because of the 4WD.
All tyres are of the same manuafacturer, size, rating and pressures +/- 1 psi. They are evenly worn across the tread although tread depths are slightly different but well within the min depth required by law (3 or 4mm).
So is it correct about the tyres and 4WD causing the problem or go elsewhere to have them balanced. RRS HSE SDV6 2012
Post #601865 Thu Jul 16 2020 9:38pm
No, and take it somewhere with Hunter Alignment equipment and know what they are doing, have the wheels balanced and 4 wheel alignment done. If they are cheap Chinese ditch finder tyres throw them away and fit something decent.
Post #601866 Thu Jul 16 2020 9:48pm
sportgoogle
Pirelli's RRS HSE SDV6 2012
Post #601868 Thu Jul 16 2020 10:25pm
Tyrefitter
As Col says ^ Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #601870 Fri Jul 17 2020 5:28am
Stevepd
Here you go
https://www.alignmycar.co.uk/ Thumbs Up
As with most things though the operator has got to know what they’re doing. The car must be put in tight tolerance mode, if not walk away...... 2006 2.7 TDV6 HSE in Cairns Blue.
Post #601871 Fri Jul 17 2020 6:27am
Tyrefitter
This was mine,before & after & I have the gear to do it.This is what you need to see when they are doing it,plus as stevepd says,make sure they put it in TTM.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #601873 Fri Jul 17 2020 6:51am
mgrover
To hijack another thread Razz Possibly a grenade thrown in...Best tyres for year round performance? Mine are...well the walls are destroyed.
Post #601904 Fri Jul 17 2020 9:25pm
