![]() | Home > General > Changing Air Compressor on a 2010 RRS |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5103 ![]() ![]() ![]() |
For £150.00 that will be a crap Chinese copy that won't last as long as it took to fit it. Pay the extra and buy a decent one.
Have a look under your car to check. My 2010 had a Hitachi and I replaced it with a Dunlop compressor as it's a straight swap.
idi Member Since: 19 Nov 2019 Location: England Posts: 134 ![]() ![]() |
Thanks for the link.
Also, before going out and buying a new compressor, you may want to consider checking and servicing the exhaust valve on your compressor first |
Strange really according to L/R Vin. AA000001 - BA708254 Hitachi fitted, BA708255 - CA725628 AMK fitted,
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
mine was upgraded from Hitachi to AMK even though it was a 2006 car so defo shoulda been Hitachi. |
I believe LR intially changed from Hitachi to AMK because there was a sourcing issue as a direct result of the Fukushima Daiichi disaster in Japan in 2011.
Had a look today. It's a Hitachi one.
Yes, they are the same part. Kev
Fitted today and goes up and down without errors now |
Well done for fitting and saving yourself a fortune. That does sound like a long time. Remember it may do this if you have raised the vehicle a few times over a short period. You need to give the compressor a bit of time to refill the air reservoir. Kev
You seem to have all the answers. That was the case as I pressed it a few times in a short period when testing. After leaving it for a few hours it works instantly now. I just need to adjust by brain to not expect to hear the error message "ding" when lowering the suspension.
Great news |
