Home > General > Seat position
abiopete
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Seat position
Occasionally i'll come to get in my car and its as if the wife has been in it and can barely fit. There's only me that drives it and its as if its reversing the lazy entrance sometimes. I've got to squeeze into it then press M1 which brings it back to driving position perfectly.
Anyone else have this issue or know whats going on? It doesn't happen all the time and i cant put my finger on what triggers it.
I have the lazy entry on and it appears to work fine except for the above.
TIA Thumbs Up L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
L494 3.0L SDV6 Autobiography MY14 in Chile Red
L320 3.0L SDV6 Autobiography MY10 in Baltic Blue (RIP first RRS love 29/03/2021 insurance total loss)
Post #601162 Thu Jul 02 2020 3:34pm
When you say "Lazy Entry" what do you mean? as I thought the MY10/13 cars no longer had that feature, used to be in the settings menu on the steering wheel, but they went over to keyless entry and the seat memory buttons in the door panel rather than the seat side trim. Or are you referring to the auto adjust on the steering column.
Post #601183 Thu Jul 02 2020 11:07pm
abiopete
When you turn off the engine and open the door, the drivers seat goes down and tilts back to give you more room when you get out. It then stays in that position until you start the car again then it will bring you back to the settings stored in M1 for your preferred driving position.
Whats been happening in my case is that at some point between me locking the car and getting back in it the seat moves to what seems to be some some random position which is hard to get in to.
Cheers,
Pete. L494 3.0L SDV6 Autobiography MY20 in Eiger Grey (Current)
Post #601185 Fri Jul 03 2020 8:07am
Have you tried using and storing your preferred settings in one of the other two memory positions to see if it does the same thing by any chance?
Post #601191 Fri Jul 03 2020 8:20am
Brit Plumber
My car does this if I have the knob on the steering column turned on. With it off I never have a problem. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #601197 Fri Jul 03 2020 9:10am
You don't need to sit in the seat to get it to go back to your setting. Just press the relevant memory slot button and it'll motor happily in to place. 2012 SDV6 - it's missing a couple of cylinders
Post #601201 Fri Jul 03 2020 9:31am
