Home > Maintenance & Modifications > Parking sensor paint flaking off
Brit Plumber
The 2 rear parking sensors in the black section of my rear bumper are showing the metal as the paints flaking off and the cap is corroding. Has anyone successful re-painted there’s? I can easily repaint them but I don’t want to paint them and then find the beeper sounding all the time.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #600963 Sun Jun 28 2020 10:43pm
I painted mine when I fitted O/F bumpers 4/5 years ago using aerosol cans, never had a problem, L/R only supply ones in primer these days ready for painting.
Post #600964 Sun Jun 28 2020 10:59pm
Brit Plumber
That’s it then Col, aerosols it is. Did you go with bog standard Matt black? 2019 5.0 SC SVA (Current)
Post #600965 Sun Jun 28 2020 11:43pm
No, as the car is Santorini Black just used a can of that and then lacquer. Believe it or not L/R actualy issued a instruction how to go about painting them, probably have a copy somewhere. Never painted the whole body as makes them tight to fit in holder.
Post #600966 Mon Jun 29 2020 12:14am
