Home > Faults & Fixes > code C1119-09
keith63
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
code C1119-09
Just had this pop up today on it's own , but with message to turn engine off .
first long journey since Lock down .. and it has been so Hot 32 degs
i have checked Hydraulic Oil in reservoir, it looks a little low just below Half way , but thin and black.
is it an easy task to flush and replace this oil ? before i start to spend big money on replacing other bits ?
Post #600796 Thu Jun 25 2020 5:40pm
When you say "just below half" do you mean the halfway line between the two marks at the top of the reservoir? Not halfway up the reservoir. 2012 SDV6 - it's missing a couple of cylinders
Post #600805 Thu Jun 25 2020 8:32pm
keith63
yeah , Half way up the reservoir , i am guessing that is too low Sad
Post #600806 Thu Jun 25 2020 8:36pm
Yes. There are three lines near the top of the reservoir that give the min and max fill levels with a middle line for good measure.
A bottle of Cold Climate PAS fluid, top it up to middle line, run it and then see what the level is. Top up as necessary. 2012 SDV6 - it's missing a couple of cylinders
Post #600823 Fri Jun 26 2020 7:39am
