Home > General > Key |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Go Compare (sorry) your keys. If you’ve only used one the previous owner may have just coded a second key and not had it cut. More likely though the wear on the barrel is not matched to the key so through lack of use. A million years ago they used to tell to rotate the usage of the keys. I’ve recently purchased a second key and got it cut. It was resistant so sprayed som WD40 on the barrel of the key and used it, worked a treat. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Jun 21 2020 6:14am |
