Home > General (L494) > AC Blower cutting out on Max after few minutes
Gibo993
2014 Autobiography. My AC was running warm so took it to friends garage and but on AC gas machine ran all checks and vacuum test all good except very little gas left in system, regassed it and now AC is freezing cold 🥶. Only issue if I press the Max AC button it runs for a few mins and cuts out. I have to select climate off/on and it works again. If I run AC at lower fan speeds it seems fine. Is this normal?
Post #600561 Sat Jun 20 2020 8:16am
Gibo993
so does everyones cut out on max is it timed? Or should it keep going??
Post #600707 Wed Jun 24 2020 6:21am
Uansjones
Mine just did exactly the same thing.
I have turned the sensitivity down to medium and it hasn’t done it again yet.....
Post #600731 Wed Jun 24 2020 10:50am
