![]() | Home > General > Suspension creak, and extended mode when access mode |
I’d say you have no obstruction, obstruction normally means something like a rock or log that would ground the car if it went to access height. I think you have resistance in your tyres and bushes etc. Do you move to access when the vehicle is rolling? That’s the kindest way to do it and limits the strain on the components as they change geometry.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
A rise to offroad height when access height is selected is a symptom of a failing exhaust valve in the compressor. That means a new compressor as the valve isn't serviceable. 2012 SDV6 - it's missing a couple of cylinders
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
this is already a replaced compressor tbf. I guess I could get yet another one. although i didnt have to replace this one |
