Home > Technical > 2.7 TDV6 will not start
evets
RRS 2007 tdv6 2.7 wont start, cranks great near fires but wont start fuel pressure ok
fuel pressure sensor ok. JLR SDD shows no faults since new fuel pressure sensor. Autel says crank shaft sensor.
fault anybod y any ideas thanks
Post #600125 Fri Jun 12 2020 11:09am
erickwan
Malaysia
Did you bleed the fuel LP system?
Post #600197 Sat Jun 13 2020 5:09pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
If the code reader is reporting a crankshaft sensor error, then it means the ECU can't see any timing pulses from the crank, and is thinking that the crank is not rotating, so it won't fire the injectors (as it has no idea what the timing relationship is).
Check the wiring for the sensor first, before replacing the sensor. If they fail, they can sometimes do it when warm, so you get the occasional engine stall, before a full on failure.
Post #600373 Wed Jun 17 2020 1:52pm
evets
Cheers Bob could well be the problem can the wiring be checked from the top as the sensor is awkward behind turbo at back of engine?
Post #600377 Wed Jun 17 2020 2:32pm
CornishRob
Sorry, I don't know, I've not had to do it on mine. Embarassed
Post #600394 Wed Jun 17 2020 7:26pm
evets
i have new sensor but there should be wires from the sensor to the ecu which can be
read?
Post #600398 Wed Jun 17 2020 8:52pm
CornishRob
Sorry, I missed that you had replied.
Not sure if you still have a problem, or what you mean, but just fit the sensor, then try starting the car. If it still won't start, re-read the error codes.
Post #601327 Sun Jul 05 2020 12:50pm
evets
Solved the problem one of the last checks looked down oil filler turned engine camshaft not turning.
Other side passenger bank providing power 2.7tdv6 passenger side bank does not provide enough power
to fire engine. removed rocker cover and all bits to reveal some teeth on exhaust camshaft not there and secondary timing belt had snapped hence camshaft not turning. Replaced cam shaft replaced secondary timing belt
re fitted ancillaries rail injectors etc 1.5 turns and away she went loads of smoke but eventually cleared.
Put timing belt back on to provide cooling starts on half a turn. half a dozen faults one is battery light red need to check alternator before fitting the rest of bits it is right at the bottom. Once confirmed ok fit the bits. Vehicle needs a full 12v circuit through car so all ecu's talk to each other which should clear faults????
Post #609870 Thu Feb 11 2021 9:41pm
