Home > Faults & Fixes > 2.7td v6 burning oil
leebrotherton
Hi all,
I’m after some advice, I have a 2008 RRS 2.7tdv6 that is burning around 5 litres of oil per 1000 miles, it also has a slight leak coming from the rocker cover and vac pump area. I’ve been advised the best solution is a recon engine from Land Rover as the oil burning in an internal engine problem.
Has anyone been in a similar situation and what would you say is the best thing to do.
I bought the car for £8000 and have spent around £4000 on repairs so far and only done 6k. It also needs discs, pads all brake pipes and new wheels as two are buckled.
Should I continue with this car or buy a newer model?
All advice would be greatly appreciated
Post #600013 Wed Jun 10 2020 7:03pm
