Home > Faults & Fixes > Dreading Parking Brake Screech |
If your leaving it in park, do it on level ground so you don’t over stress the pin.
Sun May 31 2020 9:48am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
Not ideal to leave it in Park without the handbrake applied but certainly don't even think about trying to operate the handbrake,, it will only make things worse. If you can park on a fairly level surface all the better. If you are lucky you may get away with having the rear brakes serviced and adjusted properly,, as the brakes are not siezed on is a plus point. Not knowing exactly where you are can't really help with any places that you could go to,, although I think there used to be a forum member who did mobile work in the Preston area if that's anywhere near you 2010 RRS, TDV8
Sun May 31 2020 10:00am |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Are the pins on the RRS substantially weaker than other cars?
Sun May 31 2020 5:22pm |
Not sure what you mean by pins,,, can't recall having seen it mentioned but as you can imagine if you leave it in Park you are relying on the Gearbox internals to stop the car from moving,,, not best practice. Also the old adage,,,, if you don't use it you will lose it applies to the handbrake, the less you function it, the more chance of it siezing. 2010 RRS, TDV8
Sun May 31 2020 6:44pm |
Sadly that last bit is 100% not true...
Mon Jun 01 2020 5:58pm |
I have also fallen foul of EPB seizure,, even though I used it on a regular basis. It's not just a case of using it at every opportunity,, it also has to be cleaned and kept adjusted. It's worth spending a couple of quid extra when it is being serviced to have the rear discs lifted off,, mechanism cleaned and adjusted. Whether you used it or not it is going to accumulate brake dust and dirt which will eventually cause expensive problems, it has to be usable for an MOT, even if you don't use it the tester will so it's not as if you can bury your head in the sand and pretend it's not there. I've been caught out once and never again. 2010 RRS, TDV8
Mon Jun 01 2020 7:00pm |
This is quote from a recent RRS book “All Sports had an automatic gearbox, which is a six-speed type on all except the late SDV6 models. Some people find the six-speed gearbox a little slow to respond. Both the six-speed and eight-speed types are generally robust and reliable, but early six-speed types had a problem with the parking pawl failing to engage properly. Further back along the drivetrain” 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon Jun 01 2020 9:25pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
"a little slow" .. methinks they are being kind
Tue Jun 02 2020 8:55am |
